Not seeing users from OD. Very much a newbie
  • January 8, 2015
  • 5 replies
  • 39 views
Hey guys/gals. Wanted to get some help with users not showing up in JSS.
Setup:
Mini 10.9.5, OD server with 5 local & 5 network, JSS 9.62.
Problem:
JSS see's the LDAP server but this is where I am stuck. I would think after inputing the LDAP info the users from the OD would populate into JSS. Am I wrong? Am I missing something? Is there any way to verify that JSS is talking to OD and OD is talking to JSS?
This is all just a small lab setup so I have no problems blowing stuff away and starting over. Just trying to learn some stuff here.
  • January 8, 2015
There's no automatic population into the JSS; you can add users and group that you want to have web interface access, but otherwise you won't see them listed in one place within the JSS.
You can test the connection from inside the JSS (in the LDAP settings), or you can simply try assigning a computer to a user, or test logging into Self Service as an LDAP account.
  • January 8, 2015
Really? If I had an office with 500+ employee's there is no way for JSS to populate those users from OD or maybe AD?
Am I thinking about this wrong? I need my 500 users listed in JSS so when I fire 5 of them I can lock and wipe there device, when 5 ppl move departments I can just change their groupings and so on (just making up numbers here, again this a very small lab setup).
  • January 8, 2015
Once you assign a computer to the user they will appear in the Users tab (you can use the little magnifying glass to search LDAP for them). If there's no functionality for them in the JSS, you don't want them there clogging up your interface (and your database).
For example, I work with about 100 endpoints in a company with 11,000 employees. What reason would I have to see every AD user (and service account, etc.) dumped into my JSS when I only want to see the 50-ish people who actually use the products I support? That's why the JSS doesn't list everyone it can possibly obtain information about; it only shows you what it needed to import into its own database in the course of its operation.
  • January 8, 2015
Fair point. Wasn't thinking along those lines.
I see what your saying about clogging up the database.
Right now I am just enrolling the 3-4 CPU's and 3 iOS devices via web enroll (domain/enroll). When I do this It asks for credentials. My credentials work (obviously), then it asks me to "Assign to user" with the magnifying glass. When selecting the magnifying glass it does nothing. Does not list any names, not from OD nor from the 5 random names I put into JSS. Now, lets say I ask a user to enroll via domain.com/enroll, how would I get their credentials to allow them to enroll the device and not ask to "Assign to user"?
By the way...Thanks for your feed back!
  • January 8, 2015
If you're assigning a computer to a user manually, you have to put something into the username field before searching. It doesn't list all of the options, it just performs an LDAP query for what you enter.
You can allow users to enroll their own machines by adding an LDAP group (of which they are all a member) to the "JSS Users & Groups" section of your settings, with appropriate permissions. They don't need permission to log into the JSS interface (unless you want them to), just to enroll.
