So I have setup Nudge with Jamf and using the JSON shema, which is easy to setup settings etc with the pre-defined settings.
But when it comes to editing the text in the json, the changes I make in the json schema is not listed in the GUI on any device. I have tried to edit all fields possible in the "updateElements" section, but no changes takes effect.
Any one succeeded with that ?
So it just stays the same default view all the time
