Only some management commands work for iPads...
  • January 22, 2024
  • 42 views
Hi All,
So admittedly I am a little new to Jamf Pro, but I have gone through the Jamf Pro 100 course. My question is, I have a few iPads which their MDM certificates had expired, and I had that the only 2 ways to re-enroll them were via web re-enrollment OR having to completely reset and clear all data from the iPads. I tried web re-enrollment and no luck there, so I reset the iPads. And now they have valid MDM certs, so thats good, but now when I try to send management commands, here is my issue -- commands like "enable/disable bluetooth" work just fine, but when I try to send commands like "Update Inventory", it doesn't work. Why do some commands work and others don't reach the iPad?
Best answer by fables
What version of iPadOS are these running?
They were on the latest iPadOS (iPad iOS 17.3.1).
I ended up having to wipe them once from the settings, then once they were enrolled again in Jamf Pro, I had to wipe them remotely via Jamf Pro commands. Then the rest of the commands starting working great again.
  • January 22, 2024
I'm assuming this has something to do with the iPad having some obstruction with APNs. Whether its the push certificate or something else related to that -- is that correct?
Even when I try "Blank Push", nothing comes up on the iPad.
  • January 24, 2024
  • February 12, 2024
