OSX Activation Lock issues
  • July 1, 2021
  • 11 replies
  • 64 views
Hi all,
T2 laptop, staff member left and Activation lock was enabled. Contact user and he removed the device from his Find My/iCLoud.
I am able to wipe and restore the device now, but it will not go back into DEP, either during setup or after setup with: sudo profiles renew -type enrollment.
I have tried both With Prevent Activation lock checked and unchecked in my prestage. So now this one is enrolled, not in DEP, not supervised. in Jamf, record shows Activation Lock Not Enabled.
Also, I have smart groups: 1 for Activation lock Enabled (thankfully only 8) and 1 for not enabled. When I send either option to either group, I get Command Failed to Send
I am Jamf ProCloud 10.29.2
Best answer by mkunesh
You could also try logging in with your iCloud account, enable Find My, then log back out disable Find My. Restore the OS & re-enroll to confirm it is no longer activation locked to the former employee. I've had this issue before and while it was removed on the user's end, the machine would still show activation locked until I signed in with my own iCloud account and then disabled it at the machine-level.
junjishimazaki
Did you have that person go here https://appleid.apple.com/ to remove the device?
  • July 1, 2021
Well, of course I can only say that he said he did , and he was a tech savvy guy, so no reason to think otherwise... but I did not see with my own eyes :)
  • July 1, 2021
@Sandy If you have access to gsx2.apple.com, you can check to see the status of Find my Device.
You could try the following command to see what it thinks is the assigned MDM:
sudo profiles show -type enrollment
That can help validate it's assigned in ASM/ABM.
  • July 1, 2021
  • July 27, 2021
Thanks! I had tried this and it just does nothing at all. I have used this before when devices skip DEP at activation with no issues
  • July 27, 2021
Oh, good idea! The computer is out of my hands currently, being used to sync iPads but I will give this a try when it comes back to me!
  • August 27, 2021
Hey, I finally got this laptop back in my possession and your solution worked!
"You could also try logging in with your iCloud account, enable Find My, then log back out disable Find My"
After I did this I was able to run: sudo profiles renew -type enrollment
and record shows DEP enrollment
Thank you!!
  • October 28, 2021
Hi!
A different T2 laptop that went for display repair and came back. OSX 10.15.7 Activation Locked so unable to remove the previous user's profile. Contacted user and she logged into iCloud and did not see this computer. When trying to erase and reinstall from internet recovery, it prompts for their icloud password.  I am now installing OS 15 on a second partition to see if I can sort it out using above trick.... Not sure how the Activation Lock Recovery Key can be used from jamf, manual says to enter it during setup....
Another weird thing is that when I boot to Internet Recovery using Command-Option-R (if I want to install Monterey) it boots to IR but then turns off wifi....
  • October 28, 2021
Hi!
to add to my post....
After creating a new partition on the HD in Recovery  (because I could not erase the volume due to Act. Lock) and installing Catalina, I was in fact able to deactivate the act. lock by locking and unlocking using my own Apple ID. Back to Recovery again, wiped volume, reinstalled Catalina and now all is well....
Also, my screens are SO DARK when booting to Internet Recovery: Command-Option-R , that I did not notice the Wifi icon all the way to the right, finally saw it "looking" despite actually being booted to INTERNET recovery, and was able to enter SSID and PW again...
  • May 25, 2022
Haha Me again!
Learned. new thing yesterday.
Activation Locked Monterey, T2.
User could not delete the device in iCloud.
Shut down computer for the weekend, and he was finally was able to remove device from his account.
Immediately booted to Internet Recovery, Partitioned Volume Group, reinstalled Monterey, got a message along the way that the device was NOT activation locked.
Booted, went through DEP, then could not activate Find My without putting in his Apple ID password.
1-800-800-2775 Activation Lock Issues:
Call 1 Had me repeat everything I had already done, same result.
Call 2 Had me remove device from my MDM Server temporarily,  Internet Recovery Disk Utility erase HD Install OS Same result
Call 3 Had me boot to internet recovery and use the "Erase Mac" because: it wipes more  thoroughly than Erasing volume group, or partitioning the drive. And I guess so because all is purged and device is good to go on.
  • July 13, 2022
Not to keep hammering on this, but today I was also able to use "Erase Mac' and was prompted to use my "MDM Activation Lock Recovery Code" and it worked!
Woot Woot!
Hopefully this will help someone else :)
