Package preinstall and postinstall errors
  • August 14, 2014
  • 8 replies
  • 14 views
jhbush
Forum|alt.badge.img+27
I'm having a problem figuring out some packaging errors. Any idea why these scripts would fail when added to a package? I'm basically just looking to kill the app prior to replacing it. Both scripts work fine when run manually. It's only when they are packaged do they cause the install to fail. Any help is greatly appreciated.
## preinstall
## Not supported for flat packages.
pathToScript=$0
pathToPackage=$1
targetLocation=$2
targetVolume=$3
pid=$(ps axo pid,command | grep "[A]DPassMon" | awk '{print $1}')
echo $pid
if [ "$pid" ]; then
    kill $pid
    echo "Does not exist"
if [ -d "$3/Applications/ADPassMon.app" ]; then
    rm -rf "$3/Applications/ADPassMon.app"
## postinstall
pathToScript=$0
pathToPackage=$1
targetLocation=$2
targetVolume=$3
## Finding local user
user=`ls -l /dev/console | cut -d " " -f 4`
## Launching ADPassMon
sudo -u $user open -a /Applications/ADPassMon.app
bentoms
Forum|alt.badge.img+35
  • August 14, 2014
Hi @jhbush1973,
We deploy via a DMG, so we uninstall the version that was there before, then push down the new one.
Also, I launch it via a LaunchAgent... This can then be ran post install too.
Oh & I'm doing some big fixes to my fork of ADPassMon.. If that's then version you're using.. Lemme know if anything isn't quite right.
Forum|alt.badge.img+23
  • August 14, 2014
Tested it this morning actually. Version 2 doesn't seem to change the user password!
  • August 14, 2014
Might be us however ...
stevewood
Forum|alt.badge.img+38
  • August 14, 2014
@jhbush1973 can you post the log from a failed attempt to install?
jhbush
  • August 14, 2014
@stevewood this is the error I get Install Failed: Error Domain=PKInstallErrorDomain Code=112 "An error occurred while running scripts from the package “ADPassMon196.pkg”
themacdweeb
  • August 14, 2014
@jhbush1973 i'll assume that you already researched that error code online. best practices suggests making sure that the permissions/ownership of each part of your package is set correctly.
one way to ensure that it's not a permission issue is to set things to 777.
you can do this manually via CLI or, if you're using composer, you can click on each folder and sub-folder and file and change permissions with the checkboxes at the bottom. in this case, i created a launchD script and needed to make sure all users had permission to execute, so i changed it to 777.
external image link
http://www.evernote.com/shard/s261/sh/f178dfdc-8543-48e5-b7fd-335fcbd46240/dcf2b8df5b85ff0529401af096e6c744
  • August 14, 2014
@jhbush1973
The problem is that you're searching for processes that have the name 'ADPassMon', without excluding processes that have to do with the installer. You're excluding the 'grep' process by using the bracket expression, but your .pkg includes the string you're searching for too. Because of that, the script actually kills itself.
Give these a try:
## preinstall
pathToScript=$0
pathToPackage=$1
targetLocation=$2
targetVolume=$3
pid="$(ps axo pid,command | grep "[A]DPassMon.app" | awk '{ print $1 }')"
echo "${pid}"
if [ -n "${pid}" ]; then
    kill ${pid}
if [ -d "${3}/Applications/ADPassMon.app" ]; then
    rm -rf "${3}/Applications/ADPassMon.app"
## postinstall
pathToScript=$0
pathToPackage=$1
targetLocation=$2
targetVolume=$3
user="$(ls -l /dev/console | cut -d " " -f 4)"
sudo -u "${user}" open -a /Applications/ADPassMon.app
bentoms
  • August 15, 2014
I've been looking at this, (sorry for not replying sooner here or via email).
You can just update in whilst it's running.
We just have a dmg that installs the newer version.
When the user then calls the app, it'll launch the needed. No need to stop it.
