Packaging Autodesk Maya
  • April 8, 2014
  • 100 replies
  • 761 views
Forum|alt.badge.img+23
Anyone ever tried packaging Maya as part of Autodesk's Entertainment Creation Suite? Judging by the lack of posts, i'm guessing people may have given up in disgust.
Thanks to some pretty intense googling today, i've come up with this. Full credits given in the readme.
https://github.com/franton/Maya-Postflight-Installer
This saved my bacon today. Hopefully it'll help save someone else's!
  • April 9, 2014
Yes. we are using this method since last November.
We use echo to create file with contents.
  • May 27, 2014
Works great for Maya/Mudbox 2014, thanks a million for posting it. Are you working on an updated script for Maya/Mudbox 2015? A lot of things have moved around or even disappeared. I'm taking a crack at it this morning but I am getting a registration error. I think something is wrong with the parameters of these commands:
# Install the Maya 2015 serial number.
adlmreg -i N 657F1 793G1 2015.0.0.F $MAYA-SERIAL /Library/Application Support/Autodesk/Adlm/PIT/2015/MayaConfig.pit
# Install the Mudbox 2015 serial number
adlmreg -i N 498F1 793G1 2015.0.0.F $MUDBOX-SERIAL /Library/Application Support/Autodesk/Adlm/PIT/2015/MudboxConfig.pit
...because the script errors out right near the end with:
Registration failed with code: 13
  • May 27, 2014
Okay, I've got the Maya licensing command corrected:
# Install the Maya 2015 serial number. This command works.
adlmreg -i N 657G1 793G1 2015.0.0.F $MAYA-SERIAL /Library/Application Support/Autodesk/Adlm/PIT/2015/MayaConfig.pit
...still working on Mudbox.
  • May 27, 2014
Got it. Found the answer at:
http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/2015-Product-keys-for-Autodesk-products.html
# Install the Mudbox 2015 serial number. This command works.
adlmreg -i N 498G1 793G1 2015.0.0.F $MUDBOX-SERIAL /Library/Application Support/Autodesk/Adlm/PIT/2015/MudboxConfig.pit
Here is the entire script for 2015. You may need to change a few things.
# Postflight script to install Maya and Mudbox 2015 and point it to a licence server
# Author : r.purves@arts.ac.uk
# Version : 1.0 - 8-4-2015 - Initial Version
# Hacked up for 2015, first pass. endor-moon on Jamf Nation.
# This assumes all the installers supplied by Autodesk have been installed to the root directory
# Set up variables here
SERVERADDRESS="192.168.2.1"
MAYA-SERIAL="000-00000000"
MUDBOX-SERIAL="000-0000000"
# Install the adlmgr package
installer -pkg /Install Maya 2015.app/Contents/Packages/ADLM/AdLM_standalone.mpkg -target /
installer -verboseR -pkg /Install Maya 2015.app/Contents/Packages/Maya/Maya_core2015.pkg -target /
installer -verboseR -pkg /Install Maya 2015.app/Contents/Packages/Maya/Maya_dev2015.pkg -target /
installer -verboseR -pkg /Install Maya 2015.app/Contents/Packages/Maya/Fcheck_app2015.pkg -target /
installer -verboseR -pkg /Install Maya 2015.app/Contents/Packages/Maya/Maya_AdLMconf2015.pkg -target /
installer -verboseR -pkg /Install Maya 2015.app/Contents/Packages/Maya/Maya_quicktime_components.pkg -target /
installer -verboseR -pkg /Install Maya 2015.app/Contents/Packages/DirectConnect/ADC_docs9.0.pkg -target /
installer -verboseR -pkg /Install Maya 2015.app/Contents/Packages/DirectConnect/AutodeskDirectConnect9.0.pkg -target /
installer -verboseR -pkg /Install Maya 2015.app/Contents/Packages/MentalRayPlugIn/mentalrayForMaya2015.0.pkg -target /
# That should be it for Maya, let's install Mudbox 2015.
installer -verboseR -pkg /Install Mudbox 2015.app/Contents/Resources/Mudbox/Mudbox2015.mpkg -target /
# Now install mentalray satellite and the Suite Exclusives. (I commented these out because I don't have them at the moment)
#installer -verboseR -pkg /Install mentalraysatellite 3.11.1.app/Contents/Resources/mrsat/mrsat3.11.1.mpkg -target /
#installer -verboseR -pkg /Install Suite Exclusives 2015.app/Contents/Resources/Turtle/MayaTurtlePlugIn2015.0.pkg -target /
# Create the Maya2015.lic and Mudbox2015.lic files in /private/var/flexlm
# These point to the licence server address.
mkdir /private/var/flexlm
touch /private/var/flexlm/Maya2015.lic
touch /private/var/flexlm/Mudbox2015.lic
echo "SERVER $SERVERADDRESS 0" > /private/var/flexlm/Maya2015.lic
echo "USE_SERVER" >> /private/var/flexlm/Maya2015.lic
echo "SERVER $SERVERADDRESS 0" > /private/var/flexlm/Mudbox2015.lic
echo "USE_SERVER" >> /private/var/flexlm/Mudbox2015.lic
chmod 744 /private/var/flexlm/Maya2015.lic
chmod 744 /private/var/flexlm/Mudbox2015.lic
# Create the License.env file in /Applications/Autodesk/maya2015/
touch /Applications/Autodesk/maya2015/License.env
echo "MAYA_LICENSE=unlimited" > /Applications/Autodesk/maya2015/License.env
echo "MAYA_LICENSE_METHOD=network" >> /Applications/Autodesk/maya2015/License.env
chmod 744 /Applications/Autodesk/maya2015/License.env
# Generate Mudbox licence file in /Applications/Autodesk/Mudbox2015/
touch /Applications/Autodesk/Mudbox2015/License.env
echo "MUDBOX_LICENSE=unlimited" > /Applications/Autodesk/Mudbox2015/License.env
echo "MUDBOX_LICENSE_METHOD=network" >> /Applications/Autodesk/Mudbox2015/License.env
# Disable intro screens
/usr/bin/defaults write /Library/Preferences/com.autodesk.MC3Framework MC3Enabled -int 0
# Clean up on aisle three!
rm -rf /Install Maya 2015.app/
rm -rf /Install Mudbox 2015.app/
rm -rf /Install mentalraysatellite 3.11.1.app/
rm -rf /Install Suite Exclusives 2015.app/
  • May 27, 2014
I'm on annual leave right now so I'll check it out when I'm back next week.
  • October 24, 2014
FYI, the script is broken in Yosemite but I haven't had any luck yet trying to fix it. Works great with Maya 2015 and Mudbox in Mavericks.
  • October 24, 2014
I'm not surprised actually. The product codes in that script are hard coded for the 2014 version. Replace those, and it should work ok but i've no access to that version to test anymore. What sort of errors is it throwing?
  • October 24, 2014
The error is 'RegisterPkg Error. An unexpected error has occurred during the execution of the main script
ZipImportError: can't find module 'uninstallerSQLDB'
See the Console for a detailed traceback.'
Since I'm getting the same error in the GUI I would surmise that Maya 2015 is not yet compatible with OS X 10.10 and this does not constitute an error in your script but in the underlying installer code.
  • October 24, 2014
Sounds like an excellent assumption to me too, without having seen it.
  • October 31, 2014
Checking with Autodesk I find the Maya 2015 SP5 is compatible with Yosemite now, at least when installing through the GUI.
  • November 20, 2014
Many thanks endor-moon. The script you provided above for the Autodesk Maya/Mudbox 2015 installation works like a charm.
I created a pkg. using CASPER Composer, which places the Maya and Mudbox installer on the root of Macintosh HD. After adding the pkg. and script to the JSS, I now push both out via CASPER Remote.
Many thanks
  • February 19, 2015
Thought i'd share my workflow for this one.
Compose "Install Maya 2015.app" into a .dmg - I usually stash these kinds of things in /Library/Management/
Short little script which goes something like;
if [ -a $installerLocation ]; then
$installerLocation/Contents/MacOS/setup --noui --serial_number=$serial --product_key=$product_key --license_type=kNetwork --server_name=$server
/usr/bin/logger "[STOP] Maya installer not found in staging area"
A policy copies the .dmg to /Library/Management/Install Maya 2015.app. The script installs and licenses silently. Done.
After patching the adlmreg tool because of incorrect .dylib references in 2014, this new setup method is a dream.
Hope this helps.
  • July 17, 2015
Has anyone updated the script for Maya 2016 yet? Autodesk is giving away Maya to education accounts now, so we are transitioning from paid Maya to freebie Maya. Hopefully we aren't losing anything with this transition.
  • July 17, 2015
I have a version that is working for 2016 but would like to compare it with other solutions out there. Not sure of the best way to post it here.
georgecm12
  • August 4, 2015
Ok, for the record, I've got two methods for handling Maya 2016, or rather one method with two variants.
I'm using The Luggage to create an installer that dumps "Install Maya 2016.app" into /private/tmp, then run a postinstall that actually installs Maya. Here's my makefile:
USE_PKGBUILD=1
include /usr/local/share/luggage/luggage.make
TITLE=Maya2016
REVERSE_DOMAIN=edu.school
PACKAGE_VERSION=1.0
PACKAGE_MAJOR_VERSION=`echo ${PACKAGE_VERSION} | awk -F '.' '{print $$1}'`
PACKAGE_MINOR_VERSION=`echo ${PACKAGE_VERSION} | awk -F '.' '{print $$2$$3}'`
PACKAGE_NAME=${TITLE}-${PACKAGE_VERSION}
PAYLOAD=
    pack-Maya2016
    pack-script-postinstall
l_private_tmp: l_private
    @sudo mkdir -p ${WORK_D}/private/tmp
    @sudo chown root:wheel ${WORK_D}/private/tmp
    @sudo chmod 755 ${WORK_D}/private/tmp
pack-Maya2016: l_private_tmp
    @sudo ${DITTO} Install Maya 2016.app ${WORK_D}/private/tmp/Install Maya 2016.app
    @sudo chown -R root:wheel ${WORK_D}/private/tmp/Install Maya 2016.app
    @sudo chmod 755 ${WORK_D}/private/tmp/Install Maya 2016.app
Now, here's where the variants come in. Variant 1 is a version of the script above, updated for 2016 (I removed the mudbox stuff):
# Postflight script to install Maya 2016 and point it to a licence server
# Edited by C. George for use with 2016
SERVERADDRESS="server.school.edu"
MAYA-SERIAL="123-45678901"
# Install the adlmgr packages
installer -verboseR -pkg /private/tmp/Install Maya 2016.app/Contents/Packages/ADLM/adlmapps11.pkg -target /
installer -verboseR -pkg /private/tmp/Install Maya 2016.app/Contents/Packages/ADLM/adlmflexnetclient.pkg -target /
installer -verboseR -pkg /private/tmp/Install Maya 2016.app/Contents/Packages/ADLM/adlmframework11.pkg -target /
# Install Maya 2016
installer -verboseR -pkg /private/tmp/Install Maya 2016.app/Contents/Packages/Maya/Maya_AdLMconf2016.pkg -target /
installer -verboseR -pkg /private/tmp/Install Maya 2016.app/Contents/Packages/Maya/Maya_core2016.pkg -target /
installer -verboseR -pkg /private/tmp/Install Maya 2016.app/Contents/Packages/Maya/Fcheck_app2016.pkg -target /
# Install DirectConnect
installer -verboseR -pkg /private/tmp/Install Maya 2016.app/Contents/Packages/DirectConnect/ADC_docs10.0.pkg -target /
installer -verboseR -pkg /private/tmp/Install Maya 2016.app/Contents/Packages/DirectConnect/AutodeskDirectConnect10.0.pkg -target /
# Create the Maya2016.lic and Mudbox2016.lic files in /private/var/flexlm
touch /private/var/flexlm/Maya2016.lic
echo "SERVER $SERVERADDRESS 0" > /private/var/flexlm/Maya2016.lic
echo "USE_SERVER" >> /private/var/flexlm/Maya2016.lic
chmod 744 /private/var/flexlm/Maya2016.lic
touch /Applications/Autodesk/maya2016/License.env
echo "MAYA_LICENSE=unlimited" > /Applications/Autodesk/maya2016/License.env
echo "MAYA_LICENSE_METHOD=network" >> /Applications/Autodesk/maya2016/License.env
chmod 744 /Applications/Autodesk/maya2016/License.env
/private/tmp/Install Maya 2016.app/Contents/Resources/adlmreg -i N 657H1 793H1 2016.0.0.F $MAYA-SERIAL /Library/Application Support/Autodesk/Adlm/PIT/2016/MayaConfig.pit
rm -rf /private/tmp/Install Maya 2016.app/
So, that's one postinstall. Variant 2, using a simpler postinstall, is:
/private/tmp/Install Maya 2016.app/Contents/MacOS/setup --noui --log=/tmp/Maya_2016.log --force --serial_number=123-45678901 --product_key=793H1 --license_type=kNetwork --server_name=server.school.edu
They both seem to work. Option 2 does show an icon in the dock when installing, if you install when a user is logged in, but there isn't otherwise any form of UI. Option 1 is completely silent. That said, option 2 is a lot easier to maintain - you're just calling the Autodesk installer, and you don't have to worry about which packages to install.
  • August 24, 2015
Just noticed the 2016 stuff. Well done!
I'm no longer at that organisation. You may wish to remove my former and now defunct email address from the script ;)
  • October 2, 2015
Not sure if this is any help to anyone, but I have a script to install both Maya and Mudbox 2016
I used the following for reference: -
http://knowledge.autodesk.com/support/maya/troubleshooting/caas/CloudHelp/cloudhelp/2016/ENU/Installation-Maya/files/GUID-10885D2B-D900-4DD6-BB14-B82920C2D294-htm.html
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-do-I-install-Mudbox-2016-on-Mac-silently-via-command-line-through-the-Terminal.html
# Script to install Maya and Mudbox 2016 and point it to a licence server
# This assumes that the installers have been placed under /
# Make sure you change XXX-XXXXXXXX, Product Key and YOUR-LICSERVER-HERE accordingly.
#Install Maya 2016
/Install Maya 2016.app/Contents/MacOS/setup --noui --log=/tmp/Maya_2016.log --force --serial_number=XXX-XXXXXXXX --product_key=793H1 --license_type=kNetwork --server_name=YOUR-LICSERVER-HERE
#Now install Mudbox 2016
/Install Mudbox 2016.app/Contents/MacOS/setup --noui --log=/var/log/mudbox2016install.log --force --serial_number=XXX-XXXXXXXX --product_key=793H1 --license_type=Network --server_name=YOUR-LICSERVER-HERE
#Use adlmreg to register it correctly
#Make sure you change XXX-XXXXXXXX and Product Key (793H1)accordingly
adlmreg -i N 498H1 793H1 2016.0.0.F XXX-XXXXXXXX /Library/Application Support/Autodesk/Adlm/PIT/2016/MudboxConfig.pit
#Create a mudbox.lic file and store in /private/var/flexlm/
#Make sure you change YOUR-LICSERVER-HERE accordingly, leaving the 0 in place
echo 'SERVER YOUR-LICSERVER-HERE 0' >/private/var/flexlm/mudbox2016.lic
echo 'USE_SERVER' >>/private/var/flexlm/mudbox2016.lic
#Set permissions for mudbox.lic
chmod 744 /private/var/flexlm/Mudbox2016.lic
#Remove installers from /
rm -rf /Install Maya 2016.app/
rm -rf /Install Mudbox 2016.app/
#And you are done!
  • February 9, 2016
@lakem thanks for that, that was super useful! Worked first try :)
Does anyone know if there's something similar for AutoCAD 2015 for Mac?
  • April 7, 2016
FYI, I have my script working to install Maya 2016 along with the Mental Ray plug-in. By the way, thanks for posting the Mudbox info, @lakem. I mangled the serial number below on purpose; just plug in your own. I noticed SP6 came out just the other day.
    if [ -f /Library/Installers/Install Maya 2016.app/Contents/MacOS/setup ] ;
        then
    say "Installing My ah"
# Install Maya 2016 with our serial number and server information
/Library/Installers/Install Maya 2016.app/Contents/MacOS/setup --noui --log=/Library/AdminToolBox/Maya_2016.log --force --serial_number=000-4269xxxx --product_key=793H1 --license_type=kNetwork --server_name=myserver.lan
# Call OS X installer to install Mental Ray plugin for Maya 2016
/usr/sbin/installer -pkg /Library/Installers/Install mental ray For Maya 2016.app/Contents/Packages/mentalrayForMaya2016.0.pkg -target /
  • June 15, 2016
Has anyone ever dealt with Mudbox 2016 crashing at launch after install with the following error:
WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.4 instead of 10.11.4. This is not a bug in Gestalt -- it is a documented limitation. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
I used @lakem 's install script and added Mental Ray as well. Both Maya 2016 and the Mental Ray plugin work perfect but Mudbox just continues to crash at launch with the above mentioned error even after a system reboot.
Target Machine:
Mac Pro (Early 2009)
OS X 10.11.4
NVIDIA GeForce GT 120 512MB
16GB 1066 MHz DDR3 ECC
Update: Running the same installer with the GUI allows Mudbox 2016 to launch as expected. I'm using the ECS product key and serial in the GUI and in the script. Not sure what is different here.
Update - The Sequel: Okay it seems as though it was a licensing issue. I noticed after running the GUI it was registering as a different suite. Taking a closer look I found that the script I copied had a slight fudge on the Mudbox parameter for license type (should be kNetwork not Network) minor thing though. Also, I saw
and realized the first product key was set to the standalone version of Mudbox instead of ECS (my bad for overlooking). Either way script is working now and applications launch. World saved.
  • July 14, 2016
Hi All
Does anyone have a script that will work with Maya 2016 ext 2, Mudbox 2016 and Mentalray?
I have been looking at the ones about and can almost grasp it but I am needing to deploy the software to 50 plus mac and because we are a college we have the standalone serial number and product code. obviously the license server stuff would come out of the above scripts but not sure how I would registar the product correctly.
I can get it to install ok but when launching may is asks for the serial number to registar.
I guess this type of line has to be used for both Maya and Mudbox but I am unsure what details to give at the start. How do I know what ones to put in 'N 498H1 793H1 2016.0.0.F XXX-XXXXXXXX'
Any help would be most welcome as I am tearing my hair out here, not that I have much in the first place.
Thanks
Gary
  • July 14, 2016
Check Autodesk's website for the correct keys. The keys from @lakem script that you mentioned are referencing the mud box standalone and the ECS 2016 product codes. If you are using the standalone license for Maya 2016 you may need to use the 657H1 code which is for Maya. Also, double check the keys you are using in the install parameters.
  • July 15, 2016
Thanks for the relpy Richard. Greatly appreciated.
Slowly getting there but still not working properly. Mudbox just appears in the dock for a few secs then vanishes.
Both saying registration successful. But Maya is still asking for a serial number.
Does the part mater '2016.0.0.F' and if so how of i find out what the correct one should be as the output to the pit file is slight different 2016.5 so make me think that for the ext 2 version that first number might be slightly different
apizz
Forum|alt.badge.img+15
  • July 15, 2016
Thanks for the helpful jumping off point for deploying Maya, gents.
Quick question - so I see that there are a bunch of updates for Maya. If I download the standard Maya 2016 installer, do I also have to download and install the ext 2 version? I just installed both and it seems like they're being treated as two different applications ...
  • July 18, 2016
No, the ext 2 is the latest version and comes at a complete program so you only need download it.
