PaperCut Deployment > LaunchAgent not starting for all users
  • November 30, 2017
  • 21 views
Hi Folks
I've got a small issue with my Papercut Deployment I'm testing at the moment. The package I've got seems to deploy Papercut.app to the Applications folder no worries, I can run that manually as well without issue.
I also have the com.papercut.client.plist file in /Library/LaunchAgents with 644 permissions. But this is where I'm getting stuck, the file launches under the root/localadmin account but does not launch under other users on login.
Any help would be great
grecopj
  • November 30, 2017
I have a poicy that runs a script at login. Would that be an option for you? Here is the script
!/bin/sh
echo "Launching PaperCut..."
/Applications/PCClient.app/Contents/Resources/login-hook-start "$3"
  • November 30, 2017
What OS are you seeing the issue on?
  • November 30, 2017
Did you also set the owner:group to root:wheel?
PaperCut kbase on LaunchAgent Setup
I echo the LaunchAgent into existence with a script and policy via the JSS, and have not had any issues in macOS ranging from 10.11 to 10.13 for admin, standard, and mobile users opening PCClient at login.
