Passing a script parameter into osascript in shell to create file path
  • December 13, 2018
  • 4 replies
  • 10 views
  • 6 replies
I'd like to pass a file name via a default script parameter into a bash script which calls an osascript, but am running into problems.
I've been fiddling around with something like the below, but am continually getting errors. The script does work perfectly if I hard-code the full path, and the file exists, so it must be something to do with pulling in the parameter.
$4 is set to green.png in my policy
Any ideas out there?
if [ "$4" != "" ]
then
    osascript -e 'tell application "System Events" to set picture of every desktop to ("/Library/Desktop\\\\ Pictures/$4" as POSIX file as alias)'
Best answer by mm2270
Try this:
if [ "$4" != "" ]; then
    /usr/bin/osascript << EOD
set imageName to do shell script "echo "$4""
tell application "System Events" to set picture of every desktop to ("/Library/Desktop Pictures/" & imageName as POSIX file as alias)
EOD
Edit: Changed script back to using $4
  • 7881 replies
  • December 13, 2018
Try this:
EOD
Serge
  • 26 replies
  • December 13, 2018
The variable needs to be escaped with double quotes, single quotes and double quotes again to properly escape the osascript command and pass the variable.
osascript -e 'tell application "System Events" to set picture of every desktop to ("/Library/Desktop\\\\ Pictures/"'"$4"'" as POSIX file as alias)'
  • 6 replies
  • December 13, 2018
Thanks both so much for answering - @mm2270 That is spot on - thank you so much - that has been driving me and my colleagues crazy for about 2 days!!
  • 9 replies
  • May 6, 2020
man thanks I had a similar issue that ""$VARIABLE"" was hanging us up too. Thanks for the assist.
Cookie policy
Cookie settings
