Patch Management: Firefox EA Error
  • March 29, 2023
  • 4 replies
  • 25 views
mickl089
Hello,
I noticed that the EA that Jamf provides for Firefox patch management is probably buggy. Does anyone know how to fix this? Unfortunately, it does not really show what error is here.
Thanks in advance!
Best answer by jamf-42
This is when the supplied jamf  EA code changes. Edit, check code, accept. Save.
jamf-42
  • March 29, 2023
Jaykrishna1
  • March 29, 2023
Hi Mick,
It's exactly the same what jamf-42 suggested you.. you just need to Edit, check code, accept. Save.
mickl089
  • March 29, 2023
I tried that in advance, but unfortunately it didn't work either. Have now repeated and now it works - thank you!
Jaykrishna1
  • March 29, 2023
that's great!!
