Policy for only computers in static group and in 10.14 and 10.15
  • September 3, 2020
  • 6 replies
  • 35 views
It's been awhile since I've done this but I need a policy for Filemaker 19 whose scope is a static group AND is only machines on 10.14 and 10.15.
What's the best/most elegant way to achieve this?
jbisgett
  • September 3, 2020
There doesn't appear to be a way to use Limitations on the policy because that only limits by network segment, ad membership, or ibeacons. The only way that comes to mind is to use a Smart Group that looks for members of the static group and has the OS limitations you need. Scope your policy to the Smart Group.
jbisgett
  • September 3, 2020
Computer Group member Static Group
and
( Operating System like 10.14
or
Operating System like 10.15)
Should do it I believe.
  • September 3, 2020
It's odd that a Smart Group of say Pre 10.14 and Pre 10.15 machines can't be added into Exclusions, no?
jbisgett
  • September 3, 2020
You could do it that way too and then just scope it to your static group.
jbisgett
  • September 3, 2020
Your smart group could be Operating System Not like 10.14 or Operating System Not like 10.15 (or is it and, I can never figure that out without testing)
  • September 3, 2020
@jbisgett your original suggestion worked, thanks!
