Policy not caching on some machine using every 15 trigger
  • October 29, 2012
  • 5 views
I've noticed a handful of machines that aren't executing policies using the Every 15 minutes trigger.
If I run the following command on the machine - jamf policy -id 1787 it starts to cache the package. Otherwise the machine just sits in Awaiting to execute policy...
Any ideas?
1 reply
  • September 16, 2013
I see similar problems. The every15 is also the trigger i usually use.
a jamf policy -trigger every15 does then the trick, but shouldn't that be automatic. ?!? :(
