Hi, is there an easy way to prevent Zoom from automatically launching after installing? We want to push it out to a set of computers, but don't want it to automatically open.
Prevent Zoom from automatically opening after installation is complete?
Best answer by m_donovan
I don't use Zoom but have you tried creating a package using composer? You could take the preinstalled application and drop it in the clients application folder. Just a thought like I said we don't use Zoom so I am not sure if there any specific reasons to only use the installer. It might be worth testing though.
