Privileges for Casper Remote
  • March 4, 2014
  • 11 views
We have using that we want to be able to use Caper Remote but not have full access to everything in the JSS database.
I am trying to figure out which privileges need to be given to the users, an LDAP group. They were given everything from Auditor and Enrollment as well as everything under Casper Remote.
When users try to use Casper Remote to install a package or just tell stations to install updates they receive the following error: “There was an error creating resources on the jss”.
What could I be missing? Is it having trouble creating the logs?
Best answer by strider_knh
I found the fix. I had to give them Create Policy privileges.
Here is where I found the solution, missed it the first time.
https://jamfnation.jamfsoftware.com/discussion.html?id=8235
1 reply
  • March 5, 2014
