Problems enrolling back in to Intune after Jamf enrollment
Soren
New Contributor
Hi
We are looking to move to Jamf but still needs Intune, recently i unenrolled my test mac's from Jamf to test something in Intune, but now Intune claims i need to use "another" MDM
Has anyone seen the attached "error" from company portal and perhaps even know how to do to fix it?
 My mac is
- Factory reset
- Delete in Jamf
- Deleted in AAD/Intune
Only thing missing i can some up with is that there is something in the Azure portal that is locking me.
11 REPLIES 11
dolfhoegaerts
New Contributor III
This could be a conditional access rule. Can’t you check what is failing in the logs?
Check Apple Business Manager settings as well?
Soren
New Contributor
I think it is a conditional access rule, but i do not have access to the logs for that (in process of getting it)
And they are not part of ABM, although it could be cool if JamF could add them to ABM
dolfhoegaerts
New Contributor III
If M1 devices use apple configurator to add them to ABM 😉
vinu_thankachan
Contributor
Try to exclude impacted users (that will enroll devices you want to manage in Intune and not in Jamf) from Intune - Tenant administration - Connectors and tokens - Partner device management.
the Jamf intune connecter caches the previous registred user/device information
Vinu, for us in Intune under Partner device management - showing as connection lost. Is that mean connection terminated? and in Jamf on Conditional access window, the macOS intune integration got disabled too.
dlondon
Valued Contributor
Did you assign the machine(s) over to InTune in Apple Business/School Manager?
Yes we need to move the device to intune
Soren
New Contributor
They are not in ABM atm
Soren
New Contributor
@vinu_thankachan
Vinu solution works as a round about but the "error" comes back if you remove them from the exclusion
vinu_thankachan
Contributor
Yes ,Sorry i also don't know how we can permanently clear the details from the Connectors and tokens.
sk25
Contributor
Guys, We are moving to Intune from Jamf due to less count of device. When we register the MacBook in company portal getting 'The device is not managed'.
The device is in ABM but not assigned to Jamf pro server. We did not wipe the device. We just removed the Jamf profile from system preference, deleted certificate from Keychain. Also, we are having Azure AD so no device in Azure under user information. Kindly help. Thanks
