Problems Uploading Login Page Icon
  • March 5, 2014
  • 9 views
jedfrye
Running JSS 9.24
I wanted to customize the enrollment icon so I downloaded the DefaultEnrollmentLogin.png edited it with our logo on the screen and then saved it as a .png.... The file size grew from 19KBs to 133KBs. There isn't a restriction on file size, it just says "It is recommended that you use a file with the GIF or PNG format" I also made a .gif that is 98KBs.
When I press Upload Login Page Icon, it gets to 99% and then hangs and continues to try, but never fully uploads. I also notice that the file size when uploading is different from actual size on the Mac, but didn't know if that was due to how they calculate file size.
When I click save it says the icon has been uploaded and I can upload another icon or reset the icon, but the new icon does not appear on the enrollment page. I've tried other .png and .gif images, but it still just seems to hang at 99%
It's not mission critical, but would add a nice touch to the enrollment page.
From Chrome Console, the try count on the left grows quickly once it hits this step:
<jss>
<progress>41 KB of 41 KB (99%)</progress>
<percent>99</percent>
<status>uploading</status>
<sessionExpiresEpoch>1800</sessionExpiresEpoch>
</jss>
Thanks for your help in advance.
Best answer by jedfrye
This has been resolved with 9.3
1 reply
jedfrye
  • April 14, 2014
