Procedure used for stock return ?
  • August 25, 2021
  • 11 views
Hello,
I would liked to know what procedure you used when your computers returned to stock, in particular if your computers are on DEP.
Thank you.
  • Employee
  • August 25, 2021
We started using the erase-install script this year.
https://github.com/grahampugh/erase-install
  • August 26, 2021
thank you @awoodbury
We do that too. In fact it is mostly about DEP.
Once Erase and install is done, enrollment is immediate with Big Sur because we have checked the option "Automatically advance through Setup Assistant (macOS 11 or later only)".
I wanted to know if anybody are using this option and how they handle returns to stock.
Do they enroll computers before they return to stock?
Thank you
