Question regarding JAVA and JAMF Pro
JAMFNoob
New Contributor III
Our JAMF Pro server is on version 10.25 and I am starting the process of doing an upgrade. It currently has Java 8 and Amazon Corretto 11.0.9.12.
Am I correct in assuming since it has AC 11.0.9.12 that the Java version is 11 as well and the older version of Java will have no effect on the current environment?
1 ACCEPTED SOLUTION
barpas
New Contributor II
To be honest the safest approach would be to remove the unnecessary Java 8. Just to make sure it doesn't mess up during an update. Jamf will require only Java 11 / AC11
1 REPLY 1
barpas
New Contributor II
