Re-enrolling machine with quickadd
rderewianko
Valued Contributor II
When I re-enroll a machine by pushing out quickadd to machines that are enrolled (changing managment account and casper server) I get errors is there a better way to do this? The installer reported: 2013-05-10 08:41:15.776 installer[540:6003] Package /Library/Application Support/JAMF/Downloads/QuickAdd.pkg uses a deprecated pre-10.2 format (or uses a newer format but is invalid).
1 ACCEPTED SOLUTION
donmontalvo
Esteemed Contributor II
Spurious error...Apple's own installers sometimes show it..
Package /Volumes/Mac OS X Install ESD/Packages/ServerEssentials.pkg uses a deprecated pre-10.2 format (or uses a newer format but is invalid).
https://donmontalvo.com
4 REPLIES 4
Legendary Contributor II
Are you using a current build of your QuickAdd pkg? it almost sounds like its an older version its having some issue with, but the error might be misleading.
We push out a QuickAdd in a similar policy and don't see any of these errors, typically.
rderewianko
All on 8.7
rderewianko
Dang double post
donmontalvo
