Re-order Search Categories in Jamf Pro
  • April 22, 2025
  • 21 views
I swear I stumbled upon the ability to do this once but cannot for the life of me remember where or how I did it. So... can you re-order the search categories as seen in the screenshot below? For instance, is it possible to set it so that "Name" comes up first, then "Serial Number" then "Building" instead of how it shows up now (Name, Device Phone Number, Lost Mode Enabled)? It's nitpicky, but I was almost sure it could be done to re-order these categories.
  • April 22, 2025
Forgot to add the screenshot. Oops.
  • April 22, 2025
It's annoying, but there is one way I've found to do this.  First, remove pretty much all of the items you have set to display except for the first one.  Save the search.  Edit it, and only add the next item you want on the search.  Save again.  Repeat until it's ordered the way you want.
Note that if you clone this later, you'll still have to redo that annoying work to get things displaying in the order you want them to.
  • April 22, 2025
Might be the case that this is the only option. I wonder where I saw the easy reorganization of the columns similar to this. It'd be great to click and drag them and re-org each one. Thanks!
