Recon fails, QuickAdd works, reasons why?
hkim
Contributor II
What could possibly be the difference between running Recon.app (either locally on a machine, or using Remote Inventory) and have it fail to add a computer to JSS, but creating a QuickAdd.pkg from the same App with the same credentials works? What would be the difference between the two?
0 REPLIES 0
