Recon - Remote Enrollment Error
m_higgins
Contributor
Hi All,
Completely new to Casper and currently testing a trial supplied by Jamf. When I try and use remote enrolment i get an every message every time
Recon failed to submit to the JSS. Downloading the JSS CA Certificate
There was an error.
Error enrolling computer, unable to establish trust with JSS - could not connect to the JSS
I have looked through the internet and followed some advice on recreating the CA certificate and restarting Tomcat, but no luck. I am using the built in cert.
Any help on this would be great
Thanks
1 ACCEPTED SOLUTION
m_higgins
Contributor
This has now been solved by Si Cook
The Casper Genius! - Thanks Si!
6 REPLIES 6
m_higgins
Contributor
jguz
New Contributor III
any chance you could post how you resolved this issue? we see this frequently in our environment.
jrserapio
Contributor
I would like to see the steps to resolution as well.
ant89
Contributor
What was the resolution @m.higgins ? I am currently experiencing the same....
rcorbin
Contributor II
I'm seeing this right now on one machine. @m.higgins what was the solution ?
@jguz @jrserapio @acorn Did any of you solve it ?
rcorbin
Contributor II
Maybe @stompiempls remembers what the solution was ?
