Posted on
08-30-2016
09:54 AM
- last edited on
03-04-2025
08:09 AM
by
kh-richa_mig
Hi I want to recursively remove all printers of a certain model number with a script, what I have so far is the below but while testing the script seems to exit with 0.
function rmPrinters {
thisPrinter=""
thisPrinter=`lpstat -p | grep X7855 | head -1 | cut -d " " -f 2`
if [ -z "$thisPrinter" ]; then
lpadmin -x $thisPrinter
rmPrinters{}
Can anyone help figure out why this is not working?
Solved! Go to Solution.
Posted on 08-30-2016 10:53 AM
I haven't used -z before, is that to check if the variable is populated? The rest all looks ok so I'd assume it's that telling the script to exit 0.
Another way to see if the variable is empty would be:
if [ "$thisPrinter" = "" ]; then...
That aside, I'd probably go about it a different way using a loop:
counter=$(lpstat -p | grep -c X7855)
# Outputs the number of found printers matching X7855
while [ $counter -ne 0 ]
do
thisPrinter=$(lpstat -p | grep X7855 | head -1 | cut -d " " -f 2)
counter=$(( $counter - 1 ))
# Reduces the counter by 1
done
do
done
Posted on 08-30-2016 11:05 AM
First you can replace
with just an
awk '{print $2}'
Second, I think a for loop would work better and then there is no need for a counter.
Posted on 08-31-2016 02:29 AM
@davidacland Thanks very much that worked a treat!
Have a great day.
