Hello,
Can anyone help me with the command line to remove/uncheck the "Automatically join this network" on a known network?
In Monterey's it says "Automatically join this network" and in Ventura its "Auto-Join"
We have two SSIDs and I want to make sure only the corporate is set to auto-join but not the other one.
I appreciate your help.
Thanks
Joy
I think you just have to uncheck the auto-join option in the configuration profile.
https://docs.jamf.com/best-practice-workflows/jamf-pro/configuring-wifi/Configuring_Wi-Fi_for_macOS.html
Hi @dolfhoegaerts ,
Thanks for your reply. I think this will work for us. So the profile is already pushed to all machines, I can uncheck "auto-join" in the profile and push it again and it should be fine right?
Thanks.
Hi @dolfhoegaerts
I tried to uncheck the "auto-join" on the profile which is already pushed and redistributed to the test machines but the "auto-join" from the known network in Macbook stays checked.
When I push the profile by unchecking the "auto-join" to a new computer the network stays "auto-join" unchecked in known networks.
Any other way to clear the "auto-join" check in known networks?
Thanks
