Replacement for Logout Trigger
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 09-19-2022 10:18 AM
I understand the built in log out trigger is long gone, are there any newer workflows for running scripts at logoff?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 09-19-2022 04:31 PM
Maybe this? https://github.com/aysiu/offset
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 09-22-2022 07:23 AM
Apologies for the late reply here, and reading through this it seem I will have to have a script or package dumped into this directory " /usr/local/offset/logout-every"
Correct me if Im wring here but I can see this most likely incorporating Composer so things inside scripts can still sudo and run as root.
Also am I supposed to create the directory to place packages and scripts, because"/usr/local/offset/logout-every" because the logout-every folder does not exist after installing the Offset package.
