- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 05-22-2015 03:54 AM
Hi
I was wondering if there was a reliable way to turn on right click for Apple mice? I've tried packaging up com.apple.driver.AppleHIDMouse.plist and creating a configuration profile from it, but neither work.
Any ideas would be much appreciated.
Thanks
Tim
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-22-2015 04:00 AM
This post seems to work:
https://jamfnation.jamfsoftware.com/discussion.html?id=8041#responseChild85383
Saved as a .mobileconfig file, and applied at computer level.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-22-2015 10:26 AM
Just be aware that com.apple.driver.AppleHIDMouse.plist may just be for the Apple Mighty Mouse. I think these are the other plists to look out for in case you have to deal with Magic Trackpad and Magic Mouse:
com.apple.driver.AppleBluetoothMultitouch.mouse
com.apple.driver.AppleBluetoothMultitouch.trackpad
These are the commands to change it:
defaults write com.apple.driver.AppleBluetoothMultitouch.mouse MouseButtonMode -string TwoButton
defaults write com.apple.driver.AppleBluetoothMultitouch.trackpad TrackpadRightClick -int 1
defaults write com.apple.driver.AppleHIDMouse Button2 -int 2
Then just take that plist and convert it to a config profile using MCXtoProfile.
There may be more if you're dealing with laptops. And then you have the new Retina MacBook which may have a different plist for the Force Touchpad.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-24-2015 09:31 AM
Apart from 3rd party mice (which 'just work' with right click), we only have Mighty Mouse.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-24-2015 12:53 PM
In case its of any use, here's our config profile that makes sure right click is enabled on mice and trackpads.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-24-2015 09:11 AM
Hi @davidacland
Do I apply the config profile at a computer or a user level? Do I scope computers or users?
I'm finding that it's not working consistently.
Any help would be appreciated!
Thanks
Tim
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-24-2015 09:56 AM
I normally scope at computer level to specific computers. What are the cases where it's not working? Is the profile not deploying or is it just not taking effect?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-25-2015 07:52 AM
Ok, maybe it is working. I just keep coming across Macs where right click isn't behaving as expected...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-29-2015 06:43 AM
Ok, so it's still not working. The profile appears on the Mac correctly, and even on the mouse preference pane it shows the second button as secondary click. But right click is still not working! If you manually change the second button on and off secondary click, it then works as expected.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-29-2015 04:15 PM
I found this too, after a logout / login it works fine though
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-19-2015 10:38 AM
@timlings Did you ever get this working?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-12-2016 07:55 PM
I could not get it to work either. I tried at computer level and user level. Like @timlings is saying, it shows up perfectly in the System Preferences but it does not work as expected.
I tried all other options that were offered on the forum, none are working. We are running on OS X El Capitan 10.11.4
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-04-2016 04:18 PM
Did anyone ever get this working?
My installations don't even appear to have the same plist files, unless I'm missing something.
Running 10.11.
Edit: Just tried this fix, and it did not work either: https://github.com/amsysuk/public_config_profiles/blob/master/First_Boot_Profiles/EnableRightClick.mobileconfig
I'm assuming the plist's are different, however I cannot locate them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-31-2017 10:33 AM
any updates in this with 10.11?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-03-2017 11:38 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-23-2018 05:43 AM
I'm use left click + control
