Safari v16 update
  • October 20, 2022
  • 21 views
Asifahmed
Hello All,
I deploy macOS update through Nudge, I can see those mac devices are getting updated successfully but it is not getting Safari v16 update, it is showing me pending, I need a help how can I deploy that pending Safari v16 update on all mac clients.
  • October 20, 2022
I've started testing this script for that task.  It should check if the application is open before kicking off the update.  The one change I made in my testing was that it technically errors out if there aren't any pending updates.  I just changed that from exit 1 to exit 0 since that's not a "fail" in my eyes.
Asifahmed
  • October 20, 2022
Are you doing it by BASH(softwareupdate) or anything else?
Asifahmed
  • October 20, 2022
Ohk, I got your script, thanks
