SAP Privileges Managed Installation with Jamf and adjust setting.
PE
New Contributor III
Hi All,
With Installomator SAP Privileges is installed -> added to Dock. There is also installation of an PPPC with DockToggleTimeout.mobileconfig from the website. But If I want to Toggle to admin nothing happens.
What am i missing?
thanks
1 ACCEPTED SOLUTION
PE
New Contributor III
From rtrouton @rtrouton thanks
I’ve noticed a number of folks having problems with manually packaging Privileges. I recommend using AutoPkg to build an installer for it: https://derflounder.wordpress.com/2022/04/20/building-a-privileges-installer-package-using-autopkg/
This download option with Rich describes with Autopkg works for me. Also in Jamf at Restricted Software I add this option :
From Graham Pugh
If you set the Process Name to “Privileges” rather than “Privileges.app”, the toggle option is still allowed, but the double-click option is restricted. Neat!
5 REPLIES 5
vinu_thankachan
Contributor
Check if you have the helper tool installed
https://travellingtechguy.blog/sap-privileges-app/
PE
New Contributor III
Followed the instructions and it is installed but at the part you click on "Request Privileges" it don't switch to admin and keep on the Standard User
PE
New Contributor III
From Graham Pugh
Jason33
Contributor III
I'm deploying Privileges from the Jamf App Catalog and along with a config profile I built am not having any issues. I'll definitely test out the Restriction, though, that sounds like a good feature to implement.
PE
New Contributor III
@Jason33 I try that also from the Jamf App Catalog and a config profile but it don't work here.
