SCCM Plugin - Hardware inventory not appear in resource explorer
  • May 16, 2023
  • 10 replies
  • 78 views
Hello,
I installed the sccm plugin for jamf, but I have a problem. I have the synchronization which is carried out but the data does not appear in sccm.
I looked in the logs of the plugin but I have no error, the xml files are well created.
Have you encountered this problem before ?
Regards
mvu
Forum|alt.badge.img+20
  • May 16, 2023
Have you looked at the JAMF SCCM Proxy Service Helper? Everything look correct here? Cert, URL, account/password?
Try stopping and starting the Service? Manually "Send to SCCM" by clicking the button to see if inventory in SCCM updates.
  • May 16, 2023
Hi, yes everything is ok. when I click on Send to SCCM I have the following message that appears: "Sending the alert message"
the message is stuck
  • May 16, 2023
The new followiing message appear "Finished SendToJssProxyService()" but nothing appear in sccm.
mvu
  • May 16, 2023
Did you have inventory coming in successfully before, and now it has stopped?
Might be worth reaching out to Jamf Support. Let us know what you find.
AJPinto
  • May 16, 2023
I thought that plugin was retired a couple of years ago? Microsoft is fully speed ahead to Intune at this point. I'm actually curious to see what JAMF Support has to say also.
  • May 17, 2023
Yes my last inventory was successful, but nothing in SCCM. The files are up to date in the folder C:\\Program Files (x86)\\Jamf\\Jamf SCCM Plug-in\\instancename.jamfcloud.com\\computers.
Yes I will contact support
  • May 17, 2023
I will contact support and and i will update the post
  • February 27, 2024
@AJPinto and or @tgazelle any updates here? we are only seeing about 1/4 of our machines in the C:\\Program Files (x86)\\Jamf\\Jamf SCCM Plug-in\\instancename.jamfcloud.com\\computers directory and only those machines are the ones that are being updated within SCCM.
  • February 27, 2024
We're seeing a bunch of errors in the debug folder Unable to register the device 'NAME' GUID:XXXXXXXXXXXX in 'server.name'
  • September 4, 2024
this is apparently being deprecated however there's no date just says when license expires.
