Script to Unlock System Preferences Pane
  • July 10, 2015
  • 6 replies
  • 23 views
Hi Guys,
Could any one help me?
I want to create a script to unlock the Padlock in the System Preferences Security Pane.
Is this possible?
Thanks
Mitch
acodega
Forum|alt.badge.img+15
  • July 10, 2015
That would require the password of the user who's logged in or an administrator.
Is this part of something larger you're trying to accomplish?
Forum|alt.badge.img+23
  • July 10, 2015
Not sure this is possible. You can probably remove it entirely by altering the authorisation database. Not sure how as it's not normally something I tinker with.
Chris_Hafner
Forum|alt.badge.img+27
  • July 10, 2015
Check this thread
https://jamfnation.jamfsoftware.com/discussion.html?id=11552
It sounds like the security preference pane acts a little differently using autorizatinodb than other panes, but it's sounds functional under 10.9 at the very least. That said, there's likely a specific reason why you want this pane open. That specific reason may be dealt with in a better manner than opening it completely. Just wondering?
  • July 11, 2015
I was able to do it following Greg's instructions in this video http://documentation2.macsysadmin.se/2012/video/Day2Session7.m4v . The topic you are looking for, will start after 26:32 mins on the seek bar so you will need to forward it :)
In short it will not be unlocked but users can do the change entering their own passwords. Let us know what worked for you.
  • July 15, 2015
What i'm looking to do is unlock the Padlock in the System Preferences Security Pane on 10.10
The reason I want to do this is so I user can add script to the privacy panel them self to run on the machine.
Thanks
Mitch
Chris_Hafner
  • July 15, 2015
Hopefully the methods listed above will help. I know that you're trying to give users (or a specific user) the ability to lock or unlock the security preference pane. I'm also assuming that you DON'T want to make them admins, which is why they can't unlock the preference pane themselves. What I'm asking is, what do you want them to be able to do in the security preference pane?
