Search with "Jamf Pro Management ID"?
  • April 18, 2024
  • 4 replies
  • 71 views
This might be a silly question but is there no way to search for a mobile device by it's Jamf Pro Management ID in the web ui? I couldn't find any filter options for it in advanced search.
Not the Mobile Device ID but the Management ID.
Thanks in advance!
mvu
Forum|alt.badge.img+20
  • April 18, 2024
Here?
mvu
  • April 18, 2024
Here?
I couldn't do an advanced search either, nor add it to the inventory display. You may need an extension attribute to pull this in.
  • April 18, 2024
Might do that in the future then. Just gonna use the api in the meantime, thanks!
Deverall
  • November 13, 2024
Were you able to figure this out by chance? Which API command are you using to get this also if you don't mind?
