send Lock or Wipe MDM command to devices then unmanage them
  • September 22, 2023
  • 41 views
Hello,
We have several computers and devices that have not communicated with Jamf for several months.
I wanted to know if it was possible to send an MDM Lock or Wipe command and then unmanage them.
Will these MDM commands still be deployed if the computer or the device is unmanaged but a check-in is done again?
Thank you
Best answer by sdagley
@glpi-ios I can't confirm that it works with "Devices", but for Computers I have utilized the "Stage a Lock command and them change the computer to Unmanaged" to successfully lock computers that weren't online when the Lock command was staged.
sdagley
  • September 25, 2023
Thank you for your answer @sdagley
It's perfect.
I wish you a good day
