Setting certificate trust
  • June 11, 2009
  • 16 views
Hi-
Does anyone know a scriptable way to set certificate trust level? I'm automating the installation of our root CA onto managed macs and can successfully install them, I now just need to set trust level. I don't see a way to do it with certtool on the command line.
Thanks
j
Jared F. Nichols
Desktop Engineer, Infrastructure and Operations
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
  • January 9, 2012
/usr/bin/security will add a trusted cert to the keychain. I used it when deploying MSN Messenger a few years ago when it was still hard-coded to look in the X509Anchors keychain. *pita*
You can see an example of how that would work on the last line of JAMF's importCAcert.sh script.
https://jamfnation.jamfsoftware.com/viewProductFile.html?id=135&fid=459
  • January 9, 2012
Holy cow this is an old post. Yeah I figured this out years ago.
