Posted on 11-02-2012 05:22 AM
When you define an SUS in the JSS, it defaults to a generic catalog URL that does not resolve (http://su.example.com:8088/index.sucatalog). The actual catalog URL is something more like http://su.example.com:8088/index.sucatalog/content/catalogs/others/index-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog. This makes it not usable when setting the default SUS in "Override Default Policy Settings" in the General Policy settings because the URL set on clients is not resolvable.
Is there a reason for this discrepancy, or am I doing something wrong? Instead of using the Override Default Policy Settings I am now using a separate script to se the catalog URL, which seems less elegant. Am I missing something obvious? HOw is the URL even found or defined?
Solved! Go to Solution.
Posted on 11-02-2012 01:57 PM
Hi Bryan,
Mine shows the same, yet clients get updates.
Guess there is some redirects @ play, tbh I've not looked @ it much.. It's mostly just worked for me!
Posted on 11-02-2012 05:55 AM
The JSS's behaviour is correct if you're using an ASUS.
I posted a bit about this on my blog & it contains a link to Apple's KB article that states the same: http://macmule.com/2011/07/21/how-to-connect-clients-to-lion-servers-apple-software-update-service/
Posted on 11-02-2012 11:48 AM
That's the thing, I am using an Apple SUS. The default URL generates a page not found error. I did not configure or change anything that I know of to change this. The server started on 10.7 and was recently upgraded to 10.8.
Hi Bryan,
Posted on 11-05-2012 06:03 AM
Ah, so maybe it is a false positive. Thanks for the info!
Posted on 11-05-2012 02:19 PM
Same with me. It works with my 10.8 clients when I just point them to the standard url.
Posted on 11-07-2012 09:35 AM
There is a know defect using the set server funtion, here is the response from JAMF that I got.
"That is where we run into the defect I had mentioned (D-003070). When using the Set Server option in the JSS, the URL gets written down to the client machine with a trailing space that causes it to fail. "
better to not define it and push it out with mcx guest or config profiles.. at least thats what I ended up doing
