Single command downgrade to macOS Big Sur with OR without external media from Option/Recovery Mode
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 11-08-2021 11:43 AM
I wanted to give you the opportunity to have a look at my new script.
It is primarily about the installation of the recovery/option mode, but you can also execute the command as a user with a secure token and delete your machine and reinstall it.
Install macOS Monterey from system or in option/recovery mode:
bash < <(curl -Ls wipe.it-profs.de)
Install or downgrade to Big Sur in option/recovery mode:
bash < <(curl -s wipe.it-profs.de/11)
https://macos.it-profs.de/downgrade-macos-monterey-without-usb-drive/
https://macos.it-profs.de/macos-big-sur-easy-erase/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-09-2021 02:58 AM - edited 11-09-2021 06:55 AM
I got as far as the installer cached to the external and then the installer started. It then prompted that there was no 'autherised user' on the device. Will have to now rebuild back to Monterey. Not sure why it said no authorised users.
UPDATE: tried again, without the drive being FileVaulted, and got further. This time the Big Sur installer starter but then failed with "An Error has occured preparing the upgrade"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 11-09-2021 10:26 AM
@geoff_widdowson are you running this from option/recovery mode?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 11-09-2021 03:21 PM
Yes Recovery Mode.
