Sophos Policies not applying
  • May 21, 2018
  • 5 replies
  • 20 views
Hi Guys,
I have created a policy with sophos central to make USB devices read only. This works fine on PC but not on the macs. I have applied the policy to 2 users only.
In the events it says that a usb device has been restricted by your administrator.
Could something else be blocking it?
  • May 21, 2018
Check configuration profiles -> Restrictions -> Media -> External Disks.
If "Allow" is unchecked, you'll get this message.
  • May 21, 2018
Hi Just had a look at our settings. External Disks set to Allow
  • May 21, 2018
You could use the "Read-Only" option in the Restrictions payload. I understand the want to let Sophos take care of this, but if using this accomplishes the same thing, you could run with that.
  • May 22, 2018
If it was set to read only, is there an option to allow exceptions?
  • May 22, 2018
OK Just been testing and found that the policy will apply to a mac if the computernameuser is added but this means that only that user on that machine has been added - Has anyone found a way to just add the domainuser? and it work.
