β09-20-2019 09:45 AM - edited β08-23-2021 10:04 PM
Posted on β09-22-2019 04:11 AM
@macn00b Hi,
Can you show your configuration profile settings? and on which version and buildnumber are you deploying the profile?
β09-23-2019 06:09 AM - edited β08-23-2021 10:04 PM
Posted on β09-23-2019 11:38 AM
@macn00b Please show the commands you are using to enable FileVault with fdesetup.
Some usage of fdesetup has deprecated in macOS Catalina 10.15
See lines below
FileVault & fdesetup changes β FileVault FV2 now requires User-Approved MDM Enrollment or UAMDM. You also canβt pass username/password authentication to fdesetup enable. These changes may break existing scripts, workflows or MDM agents. Be sure to check man fdesetup in 10.15 beta to read more about the new Authorization policy. You will need to follow at least one path to use fdesetup to enable FileVault Encryption.
β08-23-2021 10:02 PM - edited β08-23-2021 10:04 PM
