System Extensions
  • July 25, 2022
  • 24 views
Hey,
Im learning about system extensions and trying to manage a certain system extension from Avid NEXIS.
I have this config profile in Jamf. Iv'e double checked that the team identifier is correct.
 And I get this message when I log into the machine with the config profile and the Avid Nexis Client installed on:
 Am I missing something?
jamf-42
  • July 25, 2022
possibly its a KEXT not a system extension..  so try Approved kernel extension...
and
https://community.avid.com/forums/t/205772.aspx
  • August 18, 2022
Make sure the App is installed before you apply the Profile for the extension.
Also, what does Security Preferences say when you open it up?
