System giving error running policy _NSConcreteURLComponents unrecognized selector sent to instance 0x7fab59c4c590
  • April 18, 2017
  • 13 replies
  • 51 views
Hello,
I am troubleshooting a handful of systems that are not checking in or not successfully running policy. The system I am working on right now (10.9.5) will give the above error (_NSConcreteURLComponents unrecognized selector sent to instance 0x7fab59c4c590) when running a policy. Additionally, I have policies that are in pending state for this system and if I run sudo jamf policy on the system, it will say there are no policies to run. If I run the policy using Self-Service I get an error (non-specific) that tells me to contact support (or the administrator, I don't remember for sure).
I've tried removing jamf (sudo jamf -removeFramework) and then re-enrolling the system. I can see in the JSS the system reports the enrollment, and things look like they are ok.
This is the only system I am aware of with this specific error. Some things work like Casper Remote, but if I try to run a .pkg it will fail with the above error.
Does anyone know of a fix or what might be causing this?
Thank you,
AJ
  • April 18, 2017
What version of Jamf are you using?
  • April 18, 2017
I am on 9.98.
  • April 18, 2017
I believe you have run into a product issue (PI-003819) which resulted in all clients running 10.9.x not being able to download packages over HTTP/s. This defect has been addressed in a hotfix for 9.98 (9.98.1491860392/9.98 Hotfix 2). This is currently not released for GA (general availability) but can be obtained by contacting Jamf support. The fix will also be included in the GA 9.99 release.
  • April 18, 2017
Ok. Good to know. I will contact support tomorrow. Thank you for the information. AJ
  • April 24, 2017
@cyrus.ingraham Thanks for the heads up! I was kind of confused seeing the policy constantly running on the computer in question, until I tried pushing the pkg thru Casper Remote. Does anyone have an idea on how to fix it immediately without the hotfix?
  • April 24, 2017
Just an fyi, I contacted support and the hotfix is not available to us. At least when I checked last week. The only workaround is to use SMB or AFP.
  • April 24, 2017
@aamjohns Sorry I was misinformed about the availability. I will get clarification on this and post an update here if there are any options besides waiting for 9.99. The workaround you mentioned is the only workaround for this.
  • April 24, 2017
No apologies necessary :) I appreciate your responses and willingness to try and help. Thanks, AJ.
  • May 11, 2017
I am attempting to install a package when remotely connected to a client via SSH. When I point to the http distribution point, I receive the following message:
Downloading abc_123.pkg... 2017-05-11 14:41:41.850 jamf[89656:507] -[__NSConcreteURLComponents queryItems]: unrecognized selector sent to instance 0x7fc74a7095b0 There was an error. -[__NSConcreteURLComponents queryItems]: unrecognized selector sent to instance 0x7fc74a7095b0
So, based on the workaround, I attempted to install via smb, but the package cannot be found via that method:
root# jamf install -package "abc_123.pkg" -path "smb://jss.server.com/CasperShare/Packages" -target / -showprogress Error: The package (abc_123.pkg) could not be found.
Is my syntax above correct for the smb install? Any other ideas how to get the package installed remotely?
Thanks,
Reid
mpermann
Forum|alt.badge.img+22
  • May 11, 2017
@reidg when I try and install a package that is on a network share through the GUI I get an error message about the package not being able to be installed from a network volume. I've experienced this over AFP and SMB. I don't imagine this would work in the CLI. But I could be mistaken. I think you may need to copy the .pkg file to the local computer to say /tmp and execute the install command pointing to the local copy of the .pkg.
  • May 12, 2017
@mpermann thanks for the idea. I was able to scp the pkg to the client and install via terminal using installer.
jmahlman
  • August 11, 2017
Was this resolved in 9.99+ and up? Just want to be sure that we have to upgrade our server to fix this.
  • August 16, 2017
Can confirmation be provided that upgrading to 9.99 resolves this issue? Thanks!
