System Preferences / Privacy window popping up during Setup Assistant
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 05-25-2022 02:14 AM
Hi all,
We have a weird situation where the System Preferences window shows up during the Setup Assistant of a new laptop. We have a few policies that execute with the enrolment complete trigger, but why should that cause the System Preferences / Privacy window to pop up?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-25-2022 06:19 AM
@JureJerebic Some installers will "helpfully" open System Preferences->Privacy if they need PPPC permissions enabled. Look at what your enrollment complete policies install, and see if there is a PPPC profile ypou could pre-install so they don't trigger a privacy warning.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-25-2022 08:04 AM
That definitely looks like it, thanks. But how would I set it so that the policy executes after enrolment trigger, but the configuration profile afterwards? Or should the config profile be installed first, and then the policy? In any case, how could this be set in steps?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-25-2022 08:58 AM
@JureJerebic You need the PPPC profile installed before the software that requires it. I'd create a Smart Group to indicate if the PPPC profile isn't installed and change the package from installing on enrollment complete to installing on checkin with a scope exclusion for that smart group.
