I have a script that runs on the client, places a .plist in the lauchdaemon directory. I'm unsure how I can then have that machine be placed into a static or smart group.
Do you know if it's possible?
Create a Extension Attribute to check the .plist file exists and create smart/static group based on Extension Attribute.
Thanks.
I created a script that checks to see if the .plist exists as an extension attribute but I guess it would need to be a smart group as it seems there is no dynamic way to add machines to the static group.
