Trouble connecting to JSS when in VM
ryoshioka
New Contributor III
I am running a VM via VirtualBox to snapshot things more easily. Unfortunately, I am having connection issues when trying to connect to my JSS through Casper Admin. Getting a "(Result: 0) Check your network connection and try again", see attached screenshot. I am able to access it through the web browser in my VM. Confused as to why I am getting this error.
Any assistance is greatly appreciated! Thanks
f07a5a2218a14ca98d48b9e445887f15
1 ACCEPTED SOLUTION
ryoshioka
New Contributor III
JAMF support contacted me directly with a solution. Needed to remove the port 8443. Worked like a charm!
Hold option while launching Casper Admin, to re-enter the url of your JSS
1 REPLY 1
ryoshioka
New Contributor III
