Hello,
I have been trying to configure some new ipads using configuration and they fail to work as the config cannot be installed.
I have done this process manually and I believe that the setting that I need is in General > About > Certificate Trust Settings and then the profile swiped to yes.
Is there any way to do this automatically during enrollment or do I have something setup incorrectly on the server.
Thanks
