Hello,
I'm testing the installation of Tunnelblick on a remote Mac using jamf pro, the installation is correct. But when running Tunnelblick an error occurs:
"the installation or repair took too long or failed. Try again?"
I tried to install by creating packages in composer and downloading through jamf policies, and also through installomator. The error is still the same.
Has anyone had similar problems or how can I install and run Tunnelblick correctly?
