Unable to open projects on Garageband in Mac (Help)
  • January 19, 2020
  • 6 replies
  • 114 views
For unknown reasons, I am not able to create new projects or open anything in Garageband. Could anyone suggest a working solution? I tried to reboot the app - but same results.
Best answer by richardx49
I have had a similar problems with Garageband when I was using it on my Mac, and I solved it performing a reset in the app. Go to Settings > GarageBand, then tap Reset GarageBand. This should solve the issues.
As now I have had to shift to windows, I am looking for some solution to run Garageband on my windows desktop. Do you know any working methods for it?
  • January 27, 2020
  • January 28, 2020
Thanks @richardx49, I will try it. For Windows, You can use any PC emulator such as VWware to run garageband app. I foung this article where complete steps are well explained. SO, you can refer to that.
  • May 18, 2020
This exact same problem i am also facing garageband app. After that I uninstalled it and reinstalled it. Hope it might also works for you.
  • July 7, 2020
Re installation will solve your problem.
  • December 4, 2020
Reinstall Garageband on your Pc.
brownharris561
I don't thing it will!
