Unlock Wacom Tablets in System Preferences
  • April 8, 2014
  • 6 replies
  • 50 views
easyedc
I've tried any and every manner of method to unlock the System Preference for the 3rd party pane of Wacom Pro tablets. It's ranged from variations on this:
security authorizationdb write system.preferences allow
security authorizationdb write com.wacom.settingsPrefPane allow
exit
or
security authorizationdb write /Library/PreferencePanes/WacomTablet.prefPane allow
exit
to something like this: ```
!/bin/sh
security authorizationdb write /Library/PreferencePanes/WacomTablet.prefPane/Contents/MacOS/WacomTablet allow
exit
to pushing the MCX unlock of either: ```
<key>allow</key>
<string>com.wacom.settingsPrefPane</string>
or
<key>true</key>
<string>com.wacom.settings.PrefPane</string>
Tried both as computer and user level enforced. At this point, I'm scratching my head and wondered if others had suggestions or have gone through this before. All my tricks from the past are not working... :(
Thanks in advance.
Best answer by Merkley
I used this article to help me add the Wacom System Preference so it could be accessed. This adds it to the configuration profiles tab. I also had to do this for other 3rd party system preferences.
https://jamfnation.jamfsoftware.com/article.html?id=204
  • April 8, 2014
Can you clarify what you mean by "unlock"? I haven't used one in awhile now, but is the Wacom Preference Pane locked with a lock icon like some other ones (Network, Users & Groups, etc) or are you using Configuration Profiles or MCX and seeing the pane grayed out?
  • April 8, 2014
easyedc
  • April 9, 2014
@mm2270 it's greyed out. Sorry, should have been clearer in my post. Yes, I'm trying to allow our non-admin creative types access to set up their Wacom's as they see fit.
easyedc
  • April 9, 2014
@Merkley that was the trick. Thanks for that. I seem to never be able to find articles when I'm searching through the 'Nation.
  • February 23, 2021
What was the answer for this?. The link given is now not working. I have the same issue it's greyed out. see attached I'm trying to allow our non-admin to have access to set up their Wacom's devices.
where did this article go
