After using Casper Imaging and the target machine reboots, it uploads it's inventory however the machine is failing to update who it's managed by. In the system log I'm seeing "Checking for Computer Level Managed Preferences from server....There is a problem with your syntax. Error: This computer is not managed by the JSS. Once I manually run the Recon app on the machine it will then add the management to this machine. Any idea why the imaging process is not adding management to these machines? Has anyone else seen this?
Thanks
Allen Golbig
SKI Research Computing
Memorial Sloan-Kettering Cancer Center
