Update mobile device application scope with device exclusion
  • January 11, 2023
  • 6 views
We have an app installed on devices in our org that needs relatively frequent removal and reinstall. Most frequently, the user provides their serial number, sometimes the asset tag associated with the device (which is in the jamf pro device inventory record).
jss_url='identifier.jamfcloud.com/' username=apiuser password=apipassword authToken=$(curl -su "$username":"$password" https://"$jss_url"/api/v1/auth/token -X POST) api_token=$( /usr/bin/plutil -extract token raw - <<< "$authToken" ) #response=$(read -p "enter s/n: ") response=1070 #this is added for testing adding the device by inventory id apidata="<mobile_device_application><scope><exclusions><mobile_devices><mobile_device><id>$response</id></mobile_device></mobile_devices></exclusions></scope></mobile_device_application>" curl -ks https://"$jss_url"JSSResource/mobiledeviceapplications/id/77 -d "$apidata" -x PUT -H "Authorization: Bearer $api_token"
 Running this in CodeRunner gives an error
Running the lines in terminal gives no error but the scope does not update.
I cannot figure out why
1 reply
gda
  • January 20, 2023
Update the "x" in your last curl-command to a uppercase "X".
Lower "x" is for proxy configuration.
Uppercase "X" is for request method.
