Using a dev. JSS as a production DP
  • May 3, 2013
  • 4 views
dpertschi
Forum|alt.badge.img+19
I have a development JSS in a remote office that I'm thinking of also using as a distribution point for our production JSS.
If the dev and production CasperShare points are separately defined, maybe different local disks, things should be ok, right?
1 reply
bentoms
Forum|alt.badge.img+35
  • May 3, 2013
I'd say so.. The DP is just a file share, so as long as you have 2 shares you'll be ok.
