Using Inventory Preload Data
  • January 18, 2019
  • 33 views
Hi!
I decided to test using the Inventory Preload option on to PreStage enrollment of one computer. I got the CSV file completed and uploaded it successfully and it shows up as the Active data. After doing the PreStage enrollment (no previous record of this device), I don't see that it applied the preload data. I did only complete the serial number, department, and building fields in the CSV file since those were all I needed.
My question is, does anyone know if certain fields (besides serial number) are required for this to work? Has anyone else had this happen or something to try?
Best answer by SamF
Inventory Preload is currently only supported for mobile devices. Keep an eye out for support for computers, the Feature Request is marked as Planned.
Forum|alt.badge.img+20
  • Employee
  • January 18, 2019
  • January 18, 2019
Oh perfect, great to know! Thank you!
scottb
  • February 27, 2024
For those looking, here's the link to the FR for this...the link above only goes to top level for me.
macOS Preload
