VM not fully enrolling
  • April 20, 2021
  • 20 views
I am trying to set up a VM to test JAMF Connect using Parallels 16 and Catalina. I have set up the VM to use the boot flags, devices.smbios.serial="C01VG0EFHGFVB"
devices.mac_hw_model="MacBookPro15,1"
The VM will enroll via the /enroll URL and show up under computers, it will then get the CA and MDM profile. Both of which show as verified. The computer record shows it as enroll but not managed and no other profiles will come down.
If I run JAMF manage, it tells me the MDM profile is not approved. If I got back into the profiles pane. It is now unapproved. I have no idea how to fix this, I have never had an issue like this. Any Ideas?
Best answer by Matt_Ellis
Fixed my issue, abandoned parallels, and went with VM Ware Fusion.
  • April 20, 2021
  • April 20, 2021
Parallels was working perfect for me until two days ago. wtf
  • April 21, 2021
@B-35405 It used to work just fine for me for a long time. I have never liked it myself but it always worked till last week.
